Hi guys i have a very difficult problem here with my 1994 Mustang, it's a V6 manual.
The car is in perfect condition, runs strong.
But lately i had a crack in one of the radiator caps and it sprayed a bit of water, i took the thing out and patched it with marine tex to seal the small crack.
Before all of that my radiator fan and a/c was working fine and now none are working anymore i put them on direct 12v and they work fine but not when i put it back in place and put the battery also in place with the sudden electrical jump the battery pole gets i see the fan get a quick turn when it gets the volt but nothing happens when the temperature reaches the spot where the fan must kick in. when i turn on the a/c the fan and the a/c don't turn on either both of them must come on when i turn on the a/c
I changed the CCRM module i was leaning toward that at first that may have gone bad but it is still not working with the new one.
So i was hoping for some suggestions of what to do, maybe you guys heard or been through this before.
Thanks man
Thanks man
Sep 21, 2006 at 5:27 PM
