1994 Ford Mustang valve inspection
1994 FORD MUSTANG
SLICKVIC
Engine Mechanical problem
1994 Ford Mustang V8 Two Wheel Drive Manual
help.is new rebuilt engine on 94 5.0 302.mustang.have num 4,6,7 valve not workin proper.when taken spark plug wire wile engine running too check if the cylinders r workin proper 4,6,7.the engine stay the same but when checkin the other cylinder engine stals meaning that cylinder is working proper (right).i torque the rockers 2 their rht torque.pls dont know what else 2 run test 2 figure out in how 2 fix.pls advise[img:37be211a0b]http://www.2carpros.com/forum/automotive_pictures/581621_001_1.jpg[/img:37be211a0b]
Oct 10, 2010 at 1:49 AM
DOCFIXIT
  • 18,828 POSTS
Check for spark at plug
Check injector does it pulse?
Fuel pressure
Take compression
Oct 11, 2010 at 5:58 AM
