1994 Ford Mustang stalling
DANCINGBEAR28
  • 1994 FORD MUSTANG
  • 6 CYL
  • FWD
  • 120,897 MILES
The car seems to be getting to much gas. It starts up and then stalls out quickly. It also smells very heavy of gas. Any suggestions where to start.
Tuesday, August 25th, 2009 AT 5:11 PM
Thank you for the donation it helps the site
Check the fuel pressure if its within specs-if not could be a leaking on the fuel pressure regulator and injectors and clogged return line and also check the idle air control valve
Tuesday, August 25th, 2009 AT 6:18 PM
