1994 Ford Mustang Pinion Bearing
130,000 MILES • V8 • 2WD • AUTOMATIC
MRX
How do i replace pinion bearings?
Aug 20, 2009 at 7:05 AM
  • 31,937 POSTS
HI there,
This is a precise operation the diff center must be removed and set op in a jig to ensure that the bearing pre loads and tooth contact is precise, this is not something that you should try with out the equipment or you will destroy the diff.
Mark (mhpautos)
Aug 20, 2009 at 12:55 PM
