1994 Ford Mustang No power to the engine cooling fan
1994 FORD MUSTANG
102,000 MILES • V8 • 4WD • AUTOMATIC
JMARKE
I just bought the above mention car and it immediately started sending the water temperature gauge up into the red zone with the first 3-5 miles of driving or about 10 - 15 minutes of idling. The cooling fan on the radiator has never come on. As far as I can tell there is no power reaching the fan motor. I checked the fuses and I have replaced the temperature cooling switch. ( located by the distributor cap ) I've also notice that if I turn on anything electrical it makes the water temperature gauge spike. Any ideas ?
Sep 4, 2009 at 10:33 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for the donation!
Does turning on the vehicle's A/C cause the cooling fan to turn on?
Inspect and test the cooling fan relay, let me know how it tests.
Sep 4, 2009 at 10:45 AM
JMARKE
turning the A/C on only makes the water temp. gauge spike into the red, the A/C does not come on. I'm not sure where the cooling fan relay is located...
Sep 4, 2009 at 11:42 AM
BLUELIGHTNIN6
  • 16,542 POSTS
should be labeled " constant control relay module" or "CCRM" , it is mounted on bracket behind the engine coolant reservoir
Sep 4, 2009 at 11:59 AM
