1994 Ford Mustang leaks gas out muffler and thick smoke
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
JAHARELL
Hi i have a 1994 mustang n i recently got a new emgine put on because da exhaust came out brote whote n thick so i got a new engine put on but now it still comes out thick n it also leakd the gas out of the muffler
The car wasted 5 gallons in less than 4 minutes and it overheats fast as soon as the car is turned on
My mechanic says its the injectors so i put all new injectors in but still does that. Please help me n i will send u a nice check
Nov 23, 2009 at 9:16 PM
  • 75,988 POSTS
Check the fuel pressure regulator and for a clogged fuel return line.
If you're talking about white smoke-coolant is burning in the cylinders-Get it block and pressure tested.
Nov 23, 2009 at 9:36 PM
