1993 Ford Mustang parking brake
EBRIM
how do you adjust parking brake, mine does not have an adjusting nut like others do
Mar 20, 2009 at 7:37 AM
BLUELIGHTNIN6
  • 16,542 POSTS
It is equipped with an adjustment nut..Make sure the parking brake is fully released. Place the transmission in N . Raise and safely support the vehicle. Tighten the adjusting nut against the cable equalizer, causing rear wheel brake drag. Loosen the adjusting nut until the brakes are fully released; the wheel should spin with no drag. Lower the vehicle and check the operation of the parking brake.
https://images.2carpros.com/forum/automotive_pictures/261618_0900c15280069882_1.jpg
Thanks for using 2CarPros.com!
Mar 11, 2021 at 6:29 AM
