1993 Ford Mustang My catalytic converter
103,000 MILES • 4 CYL • FWD • AUTOMATIC
KITTYMAMADEE
It got me to work fine that morning. I got in it to leave and it rattled and shook like a coffee can full of nickles. My daughter followed me and said it smelled like a bad perm. I got not take off power at corners. After I took off, It would kick in and take off, then slow down, speed up slow down, all the way home. Do you think it's my catalytic converter and should I try to drive it to a shop or have it towed? I don't want to make it worse!
Jul 3, 2008 at 1:33 PM
MERLIN2021
  • 17,250 POSTS
The problem now is how much of the busted up honeycomb bed material is stuck downstream from the converter? The muffler will trap this stuff, pipes too! The more you drive it, the more is trapped!
Jul 3, 2008 at 1:38 PM
MUSTANG87
  • 261 POSTS
i dont quite get u shaking thing but your smart by thinking one of the cats might be bad.if your shop is not far drive it slow but checking your temp making sure it dont over heat.rattles under car most of time its the cats and if car bogging down.but then again im not looking and test driving it ,may also be a bad fuel pump to or clogged fuel filter etc.good luck.
Jul 3, 2008 at 1:42 PM
MERLIN2021
  • 17,250 POSTS
Jul 3, 2008 at 1:59 PM
