car started to make a clicking type starter sound?
3,500 MILES • V8 • 2WD • MANUAL
CHADHAM
I was changing the starter out and putting a new one in. when i put the new one in the car started to make a clicking type sound. it didn't do that ever before what could be the problem?
Dec 13, 2007 at 12:42 PM
  • 31,937 POSTS
Hi there,
When is the clicking sound happening exactly?
Mark (mhpautos)
Dec 13, 2007 at 12:46 PM
  • 55,676 POSTS
Either the battery is low or the starter is defective, here is a guide to help you test the battery and if okay I would get another starter motor which is common to get a defective unit form the parts store.
1. Disconnect battery ground cable.
2. Raise and support front of vehicle.
3. Disconnect starter cable from starter.
4. Remove starter motor attaching bolts and the starter.
5. Reverse procedure to install, torque starter retaining bolts to 15-20 ft. lbs.
Here is a guide to help walk you through the steps of the starter replacement.
Oct 2, 2024 at 9:45 AM
