1993 Ford Mustang IDLING
BIG LJD
  • 1993 FORD MUSTANG
  • V8
  • 660,000 MILES
AFTHER STARTING MY CAR AT COLD TEMPERATURE IT DOESENT WANT TO IDLE RIGHT, I REAVE THE ENGINE, A COUPLE OF TIMES IT IDLES RIGHT, AFTHER DRIVING MY CAR AROUND AT CITY SPEED FOR BOUT THIRTY MINUTES MINUTES, AT CITY SPEEDAND THE CAR TEMPERATURE IS AT NORMAL OPERATION TEMPERATURE RANGE, IN DRIVING WHILE STOPPED, THE CAR WANT IDLE RIGHT, AND I CAN HEAR THE CAR SUCKING FOR AIR. WHAT IS THIS AND HOW MUCH IT WOULD COAST TO FIX.
Thursday, December 4th, 2008 AT 12:53 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Most often it's an oxygen sensor, but it can also be a number of other components including : plugs, plug wires, burned valves, vacuum leak, dirty/faulty idle air control valve or dirty air filter.
Does the engine light appear with car running? If so, scan for diagnostic codes. If not, you may want to start with a good tune up which normally includes plugs, wires, fluids, and filters.
Hope this helped.
Thursday, December 4th, 2008 AT 1:11 AM
