1993 Ford Mustang HEATER
500,000 MILES • 4 CYL • 4WD • AUTOMATIC
BP_BETTYLOPEZ
How or where should I look to fix the "heater"?
On cold morning cars defroster wont work, where should I look to fix?
Car does shakes a litle bit, what should I go check to fix?
My dash board lights work but certain section are dim, where or what should I look into to fix?
If you could please inform me with any information, to look into it and then take to a mechanic? instead of always getting charged too much, I just want to address those issues. Not, what mechanics around my neighboorhood usually do.
Will be waiting for an answer, thank you so much.
Dec 8, 2008 at 1:46 PM
DAVE H
  • 13,383 POSTS
does the heater just blow cold air .. or does it do nothing at all ?? will need a little more info on the "shakes" .. does it shake all the time .. at a stop sign .. first thing in the morning .. all day .. do you have water loss or white smoke from exhaust ??
a couple of the dash bulbs have probably blown and need replacing ?? let me know ...
Dec 8, 2008 at 11:50 PM
