1993 Ford Mustang driver door won't open
121,000 MILES • 4 CYL • 2WD • AUTOMATIC
MHARRISON052292
one day i went to open the door and the clip holding the rod on to the outside door handle broke. so i got in from the pass. side and it wouldn't open from the inside either.so i thought the power door lock motor went bad so i removed it. that didn't help i'm stumped. what could cause this?
Dec 8, 2009 at 3:51 PM
  • 110,248 POSTS
Chances are the linkage came apart on that door too. Have you removed the door panel to check the linkage?
Dec 11, 2009 at 2:30 PM
