1993 Ford Mustang 1993 Ignition problem.
1993 FORD MUSTANG
178,000 MILES • 4 CYL • 2WD • MANUAL
DARTZERO7
About 5 or 6 months ago my car started skipping. It wouldn't do it all the time but when it did the RPM gauge would read half RPMs. ex. it would really be at 4000 but it would only read 2000. Today i was going down the road and the car just cut off for no reason at all. Also when it starts it sputters and the whole cars shakes. Im thinking its the Ignition coil. Ive replaced plugs and wires, air filter, I cant get the codes read anywhere because it's a 1993. Any help is greatly appreciated.
May 7, 2009 at 3:49 PM
BUKOWSKI90
[quote:49dabd290a="dartzero7"]Engine Mechanical problem
1993 Ford Mustang 4 cyl Two Wheel Drive Manual 178000 miles
About 5 or 6 months ago my car started skipping. It wouldn't do it all the time but when it did the RPM gauge would read half RPMs. ex. it would really be at 4000 but it would only read 2000. Today i was going down the road and the car just cut off for no reason at all. Also when it starts it sputters and the whole cars shakes. Im thinking its the Ignition coil. Ive replaced plugs and wires, air filter, I cant get the codes read anywhere because it's a 1993. Any help is greatly appreciated.[/quote:49dabd290a]
I have a 95 that did the same thing and i replaced the ignition control module, and that solved my problems, seeing how you have replaced all those other parts, also check fuel filter just to be sure its not really plugged.
May 11, 2009 at 11:49 PM
