1992 Ford Mustang Shaking
GROCHOWSKIGRK
Other Category problem
1992 Ford Mustang V8 Two Wheel Drive Manual 173k miles
I just went to town fair tire to get all four tires replaced and got an alignment, and tires balanced. But i am still having problems with my car shaking. at around 45 mph my car starts shaking then stops around 50 mph. then when I reach about 75 mph my car starts to shake uncontrollably and has no signs of stopping when i try going faster, shifter starts making a ringing noise and everything inside the car starts to shake and vibrate.
Jan 14, 2008 at 3:07 AM
MUSTANG87
  • 261 POSTS
hello,sounds like it still needs a front tire balance.maybe they did not do it even if they told u they did.shops r wolfs and they ripp poeple off all the time.take the car back to them dont let them get off easy.you know you can also have a bad rim warped .and it will shake like that to.get the rims checked in a tire shop and if one or more of the rims r bad replace.also my 87 mustang shaked alot after 70miles an hour and well i had bad motor mounts.you never know you might wanna check all these possible areas.check balance front>>bad rim>>motor mounts.o and also check the transmision mount.best of luck to you fellow ford fan.
Jan 14, 2008 at 6:42 AM
