1992 Ford Mustang no distributor
MIKEHJ
Electrical problem
1992 Ford Mustang 4 cyl Two Wheel Drive Automatic
where is the distributor on a 1992 Ford Mustang 2.3L where is the dule plug inhibit contron at and i have no spark on my right side if i change my right side coil pack will that fix it or can it be somthing else
May 28, 2009 at 3:00 PM
  • 75,988 POSTS
If you know what a sparkplug wire is one end of it will go to the sparkplug and the end goes to the distributor or to a coil packs call a DIS the other type will a COP system
May 28, 2009 at 4:44 PM
MIKEHJ
May 28, 2009 at 5:59 PM
  • 75,988 POSTS
Try swapping coils and see what happens still the same check the ignition contol module and crankshaft position sensor.
May 29, 2009 at 8:54 AM
