1992 Ford Mustang clutch cable
TKKUBAIKO
  • 1992 FORD MUSTANG
  • V8
  • MANUAL
  • 11,000 MILES
I just had a new clutch, throwout bearings, and pressure plate installed in my mustang, but after driving it less than 200 miles the car does not want to go into gear. When you put it in 1st. It starts to creep forward and is very hard to get into the other gears. Is it possible that the clutch was put in wrong? I also put a H- pipe on the car as well and someone told me maybe that the heat off the pipes and manifold are heating the cable and it is stretching, is this possible?
Tuesday, April 8th, 2008 AT 10:58 AM
MUSTANG87
  • 261 POSTS
First try pulling up towards u the pedal maybe they didnt pull it up when instsalled new one. Just put ur foot under clutch pedal and pull it up some hard to see if its adjusted. If that doesnt work you will need to get the pedal assembly fixed or better yet just buy manual adjusting quadrant. Its better than stock self adjusting. You can get a manual adjust quadrant in summit. Com fords always have those problems crappy self adjusting cables good luck
Friday, April 11th, 2008 AT 5:13 PM
