1992 Ford Mustang car vibrates
160,000 MILES • V8 • 2WD • MANUAL
STANGBOY92
when I start my car it vibrates instantly..It vibrates through the steering wheel and through the gear stifter badly..thought it could be motor mounts but tried to shake engine by hand but didnt move..
Feb 18, 2010 at 7:16 AM
MERLIN2021
  • 17,250 POSTS
Shaling the motor by hand? Hello Hercules! Try a fllor jack and jacking it, you would see instant results. Use a block of wood, and watch as you jack it.
Feb 18, 2010 at 7:33 AM
STANGBOY92
ok well where do i put the jack?? would it go under the oil pan?
Feb 18, 2010 at 8:44 AM
MERLIN2021
  • 17,250 POSTS
Crank pulley with a block of wood, jack slowly incase the mounts are OK...You should be able to see split in the mount on either side visually, but the jack will remove all doubt.
Feb 18, 2010 at 9:38 AM
