1991 Ford Mustang Electric door lock
1991 FORD MUSTANG
103,000 MILES • V8 • 2WD • MANUAL
JEF1991
I need to replace the peice that locks the door(electric). I have the door panel off and can see the part, But not sure how to remove it. Any idead on how to do this.
Dec 26, 2008 at 3:28 PM
DAVE H
  • 13,384 POSTS
REMOVAL & INSTALLATION
DOOR LOCK ACTUATOR MOTOR
Removal & Installation
Remove door trim panel and water shield. Disconnect actuator motor link from door latch. Remove screws or drill out rivets attaching actuator motor to door. Disconnect wiring connector. Remove motor. To install, reverse removal procedure.
NOTE:Make sure actuator boot is not twisted during installation. Pop-rivet must be installed with bracket base tight to inner panel.
Dec 26, 2008 at 10:26 PM
