1991 Ford Mustang
236,000 MILES • 4 CYL • 2WD • AUTOMATIC
ICEMAN27573
Started my car this morning realized I forgot something.Then when I turned the ignition swith I hear a knock and the engine want start.Take the ignition module(less than one week old) to get it tested and it fails.Get another one at a different store install it turn the swicth, knock followed by slight backfire engine doesn't start.Checked the timing belt and was able to slide it off without loosening the tensioner but it seemed to still be alligned.Line up timing marks install a new belt with about 1/8" to 1/4" of slack.The knock is still there and engine wont start.Could this be related to the computer or starter?
Jan 14, 2009 at 10:23 AM
DAVE H
  • 13,383 POSTS
you will need to check compression .. may have bent valves ...
Jan 14, 2009 at 10:59 AM
ICEMAN27573
Found the problem the aux. shaft sprocket was not in the right spot.Haynes repair manual had no information about where it needed to be.Still not sure it is in the right place,but the car is running with just a slight hesitation when acellerating from a dead stop.Thanks for your help...
Jan 14, 2009 at 4:07 PM
DAVE H
  • 13,383 POSTS
AUXILIARY SHAFT & BEARINGS Removal Remove timing belt. See TIMING BELT in this article. Using dial indicator, check auxiliary shaft end play. End play should be .001-.007" (.02-.18 mm). If end play is not within specification, replace retaining plate. Remove auxiliary shaft sprocket and auxiliary shaft cover. See Fig. 5. Remove retaining plate. Remove auxiliary shaft. Use care not to damage bearing surfaces. If removing auxiliary shaft bearings, use slide hammer and Puller (T58L-101-B) to remove bearings. Inspection Inspect components for damage. Check auxiliary shaft-to-bearing clearance. Clearance should be .0006-.0026" (.015-.066 mm). Replace components as necessary. Installation To install, reverse removal procedure. Use driver to install bearings. Ensure bearing oil holes align with holes of cylinder block. Coat auxiliary shaft with engine oil before installing. Tighten bolts to specification. See TORQUE SPECIFICATIONS table at end of article.
https://images.2carpros.com/forum/automotive_pictures/266999_sprocket_1.jpg
Jan 15, 2009 at 11:41 AM
