1990 Ford Mustang Vibration at 60mph
70,000 MILES • V8 • 2WD • MANUAL
MUSTANGPAT83
When i get over about 60 mph my car has vibrates pretty bad, I was wonder what could be some of the causes of this?
Jan 21, 2009 at 2:18 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Most common problem is a misaligned front and/or rear end. A more serious problem would be worn ball joints or worn wheel bearings. Inspect these by wiggling wheel while vehicle is raised. Should not have play in it. If OK, may also have a bad tire or an improperly balanced tire.
Thanks for using 2CarPros.com !
Jan 21, 2009 at 2:21 PM
