1990 Ford Mustang Trouble with steering
1990 FORD MUSTANG
165,000 MILES • V8 • 2WD • MANUAL
ADRIAN90
I have a fast thudding sound coming from the driverside front wheel well my steerign wheel does not vibrate its just that noise. I crawled under the car an i saw that the pinion on the same wheel well is bent could this be the problem? The noise occurs in both high speed and low speed...
Jun 17, 2008 at 2:35 PM
  • 31,937 POSTS
Hi there,
You should have the pressure tested with a master gauge, Hot idle is the reading that will be critical. Also check max pressure this will give a fair indication as to the relief valve operation. You will not be able to gauge bearing condition as this will also have a big part in maintaining good oil pressure. Get some reading s done and re post.
mark (mhpautos)
Jul 6, 2008 at 6:21 PM
