1990 Ford Mustang COntinuous fuel pump running
257,000 MILES • V8 • 2WD • MANUAL
JAYS269
My fuel pump stays on continuously even when the car is turned off. I have to disconnect the battery inorder to turn it off. I notice what sounds like an air leak coming from the front of the engine around the distributor or fuel injectors. It stops when the fuel pump stops. I can't see anything disconnected.
Thanks
Dec 4, 2008 at 3:03 AM
JDL
  • 16,098 POSTS
As far as the fuel pump issue, you might try checking the fuel pump relay and circuits. My info says it's located under the driver seat.
Dec 4, 2008 at 4:09 AM
