1989 Ford Mustang Wont turn on as if battery is dead
1989 FORD MUSTANG
30,000 MILES • V8 • 2WD • MANUAL
ADOLFO81
I have this problem to where if i drive my stang for about 20 to 30 minutes , turn it off and try to turn it back on it wont start. It will try as if the battery is going dead. If I wait for 20 minutes or so it will turn back on as if nothing every happened. I have replaced the battery, starter, and alternator and still no luck. Any help???
Jul 16, 2009 at 6:49 AM
MERLIN2021
  • 17,250 POSTS
It usually turns out to be heat from the engine affecting the starter, especially if it starts OK after sitting for a while, but cranks slow when hot, also check to make sure the engine isnt running too hot, and check base timing by unplugging the spout connector and checking the timing with a timing light.
Engines will crank slow if timing is too far advanced, and it will ping or knock under load! Battery and cables can be a problem too...Check for voltage drop at cables, especially the negative cable.
Jul 16, 2009 at 6:56 AM
