1989 Ford Mustang help
1989 FORD MUSTANG
KIETA1
  • 9 POSTS
Engine Cooling problem
1989 Ford Mustang 4 cyl Two Wheel Drive Automatic
this car is overheating /i replaced the fan motor .it was bad replaced cooling fan temp switch/coolant temp sending unit.i think it's fan controller but my book doesn't have a location.any help is appreciated
Jul 16, 2009 at 11:08 PM
  • CAR REPAIR CONTRIBUTOR
Have you replaced the thermostat? If not do so-and check the radiator if its clogged-up and also if the water pump is functioning -if both okay get it block and pressure tested.
Jul 16, 2009 at 11:15 PM
KIETA1
  • 9 POSTS
thermostat is new radiator is good fan is not comming on
Jul 17, 2009 at 11:00 AM
KIETA1
  • 9 POSTS
i have a manual for the car but i doesn't give me a location of the fan control switch
Jul 17, 2009 at 11:04 AM
Could be a fuse, fan relay, coolant temperature sending unit or the engine coolant temperature sensor
Jul 17, 2009 at 6:43 PM
KIETA1
  • 9 POSTS
guess you'r not on the same page /the new fan doesn't come on i'm looking for the fan controller for the radiator location
Jul 17, 2009 at 7:51 PM
What fan motor are you talking about -is it the electric fan motor for the radiator or the blower motor for AC/heater? If its the radiator fan motor you best check what I've gave you. There's no fan controller.
If one of the items is defective the radiator fan will never come on. Good Luck
Jul 17, 2009 at 7:58 PM
KIETA1
  • 9 POSTS
electric fan to the radiator not comming on
Jul 17, 2009 at 8:07 PM
BRUTIS_34
  • 5 POSTS
i had the same thing happen to me, i replace the fan motor and still did not come on, you have a fuse that is no good under the hood, replace the blowen fuse and your fan will come on.
Jul 20, 2009 at 7:49 AM
KIETA1
  • 9 POSTS
all fuses good need location of radiator fan controller if you have that information
Jul 20, 2009 at 11:24 AM
KIETA1
  • 9 POSTS
are you ase certified or backyard mechanic///////////I HAVE NO HELP
Jul 20, 2009 at 11:30 AM
BRUTIS_34
  • 5 POSTS
well bro i was just telling what it did when i have that happen to my car. I got a new fan motor and put it on, and still did not work. so i looked under the hood and i had a fuse that was bad or the name is relay fuse. so i replaced that and my fan worked fine. there is not switch so dont look for one you will be mad tring to look for it. just fine the fuse under your hood in the black fuse box, replace the bad one bro.
Jul 21, 2009 at 2:17 PM
KIETA1
  • 9 POSTS
no help
Jul 30, 2009 at 10:17 AM
KIETA1
  • 9 POSTS
i would like to make a small
donation for no help ///0000000000
Aug 1, 2009 at 4:47 AM
