1989 Ford Mustang distributor removal
TRACTORFARMALL
Electrical problem
1989 Ford Mustang 4 cyl Two Wheel Drive Automatic 141k miles
i can not remove the distributor lock down bolt please give size of bolt head and if sae or metric does it require a dist. wrench? access is fairly itght and on an angle. thanks
Jun 15, 2008 at 12:43 AM
BLACKOP555
  • 10,386 POSTS
you will need a distributor wrench to get at it, they have the proper size wrench just give make and model when you get the wrench i belive it may be 3/8. standard SAE
Jun 15, 2008 at 5:30 AM
