1989 Ford Mustang Distributor
180,000 MILES • V8 • 2WD • MANUAL
SIZEMORELUKE
It was working fine a little ruff like it wasn't hitting all the
points I went to take off and as I went into 2nd it stalled and shut off I tried to start it again and it wants to start I thought maybe it needed gas I put gas no turn over finally I looked under the distributor cap and I see a loose piece of metal I pulled it out it looks like a tooth not a broken piece but it was disconnected from somewhere still won't start . I'm begging for help someone please let's know what I should do?
Mar 4, 2010 at 1:26 AM
RACEFAN966
  • 5,029 POSTS
Can you include a pic of what you found? Does is look like it could be one of the teeth on the distributor pic below?
https://images.2carpros.com/forum/automotive_pictures/249564_distributor_1.jpg
Mar 5, 2010 at 2:22 AM
