1988 Ford Mustang No engine cooling fan operation (electric
1988 FORD MUSTANG
68,000 MILES • 4 CYL • 2WD • AUTOMATIC
JNHOL
Fan runs when power applied with tester, eleminating the fan motor, no automatic operation when engine reaches operating temp. Car has not been driven for two years. Question: which sensor controls the cooling fan and where is it located?
Thank you for all your help.
jnhol
Aug 17, 2009 at 3:54 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check the cooling fan controller, located under the instrument panel between the steering column and left side cowl panel. it should have 2 relays on controller. if these are OK, check coolant temperature switch. Use jumper wire between connector and ground on circuit # 45 (yellow / red wire). Turn ignition on, if fan runs replace switch.
Aug 17, 2009 at 5:16 AM
