1985 Ford Mustang GT Won't Start
Sounds rare to me... at least here around Washington, DC it is. It's her car.
Suggested Repair
Scan the engine computer for fault codes to identify why the injectors are not opening. Keep the original fuel-injection system rather than converting to a carburetor if it can be made to work properly.
Conversation Summary
A 1985 Ford Mustang GT 5.0 cranks but will not start or keep running unless fuel is poured into the throttle body, then dies when that fuel is burned. Fuel pressure was reported at 19 psi, and the injectors have power but are not opening despite replacement of the computer, fuel pump, injectors, and other parts. Removing the fuel shutoff did not help, and the owner wants the car kept original rather than converted to a carburetor. The expert advised scanning for computer fault codes and said a working fuel-injection system is preferable to a carburetor. Other replies mentioned a missing distributor gear tooth on a similar car and questioned whether a stock 1985 GT used throttle-body injection.
