1984 Ford Mustang want start
1984 FORD MUSTANG
BOBBIE JORDAN
Interior problem
1984 Ford Mustang 6 cyl Front Wheel Drive Automatic
it had a bad plug on the engine controle module.i replaced it but it tries to stars but doesent
Aug 10, 2010 at 11:04 AM
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure with a fuel pressure tester designed for your fuel system to rule out the fuel filter/fuel pick-up strainer/fuel pump/pressure regulator and also listen to the injector/s are they pulsing or hook up a noid light and see if it flashing-Depends on what type ignition system is yours,No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, camshaft and crankshaft position sensors and computer Note: If it doesn't apply to your vehicle disregard it meaning if it doesn't come with one ignore it and keep testing
Aug 10, 2010 at 11:07 AM
