1984 Ford Mustang random stalling when clutch is pushed in
84STANGGUY
Other Category problem
1984 Ford Mustang Engine Size unknown Two Wheel Drive Manual 93699 miles
I have a 1984 ford mustang with the four cylinder turbo. sometimes when i push in the clutch it stalls. I have replaced the brake booster because it was leaking internally and now it doesnt stall as often but it still does .... i checked all the vacuum lines and they look fine. Any help would be great. thanks
Nov 30, 2007 at 6:54 PM
  • 75,988 POSTS
Last major tune-up?
For a start have the EGR and idle speed control motor/IACV check
Dec 2, 2007 at 5:22 AM
  • 55,649 POSTS
I have seen the throwout bearing lock up and when you push the clutch in a stalls the engine, can you hear it making noise when you press the clutch in? If so I would pull the transmission out, here is a video that can help you.
https://youtu.be/JpzefqEeVGE?si=z_hPA1LMHOM1AS-O
Let us know how it goes
Jun 25, 2024 at 7:49 AM
