1984 Ford Mustang oil
STEELDIGGER
Engine Performance problem
1984 Ford Mustang V8 Two Wheel Drive Automatic
i changed the oil and statered it up and then i heard a pop and all the oil i just put in came out the oil plig was steel in. the oil that i pould out was gold and milky
Oct 22, 2009 at 6:29 PM
  • 110,248 POSTS
Did the oil come out of the drain plug on the oil pan? Also, if the oil was milky white, it sounds like you have a bad head gasket that is allowing coolant to enter the engine / oil.
Oct 23, 2009 at 12:10 AM
