Hoping for even some basic info
34 Ford pickup- original straight axle is long gone.
trying to put a complete front end (with cross-
member) in place from a 1979 Pinto/Mustang ll.
If I can get a basic start placement to do tack-welds
and then adjust for reasonably close caster setting
the rest will be governed by having all independent
components in place already
Is there a way without the fancy alignment tools to
check the caster setting by somehow measuring the
differential between extreme left and extreme right?
Please and Thank You for any help !!
P.S. The 34 is NON-MOVEABLE
Jack L
Jack L
Dec 10, 2007 at 11:47 AM
