1973 Ford Mustang Blown fuse
38,900 MILES • V8 • 2WD • AUTOMATIC
MRKENT
I just replaced the fuse (14Amp) on my 1973 Mustang, and it blew almost immedietly. I next went looking for the blower motor, but to no avail. Any help would be appriciated.
Thanks
Oct 29, 2008 at 5:00 AM
JNOVACK
  • 723 POSTS
the bower motor is in the heater assembly under dash heres how to remove
1972-73 Models
Drain the engine coolant.
Disconnect the two heater hoses from the core tubes.
Remove the glove box for access and remove the right vent air duct assembly (one duct-to-upper cowl mounting screw and three duct-to-blower mounting nuts).
Disconnect the two control cables from the heater case assembly.
Remove the defroster-to-plenum snap clip.
Disconnect the electrical wiring from the resistor assembly.
Remove the heater case assembly (four heater case-to-dash panel mounting stud nuts).
Install in the reverse of above.
Oct 29, 2008 at 5:50 AM
