71 Mach 1 429 super cobra jet
While driving about 3000rpm with engine already warm the oil pressure started slowly dropping and in 5 minutes had dropped to zero. The heat indicator did not show a increase and there was no difference in engine sound so I kept driving and the pressure started coming back and showed one half of what it normally shows. I drove it about two miles to home and turned it off.
Could this be something other than the oil pump or the gauge. I have also noticed sometimes when i turn on the lights that the engine temperature will increase. Is there an electrical component that can affect the gauge readings?
How can I trouble shoot the oil pressure problem?
Oct 4, 2010 at 7:14 AM
