1971 Ford Mustang ignition key lock cylinder will not sprin
JRLG
Electrical problem
1971 Ford Mustang V8 Two Wheel Drive Automatic
I have a problem with my 71 Mach 1 ignition key lock cylinder. It will not spring back to run when you start it, it stays all the way forward. I had to replace the key lock cylinder and now it has no spring return at all. There are two bent wire/springs in there. They look like they are the size of paper clips. Anyway, if anyone knows how I can fix this, or where I can get newer return springs, I would appreciate the help.
Nov 1, 2009 at 1:21 PM
JRLG
I guess they don't answer unless you donate. I don't buy something unless I know what it is. I guess we're at a stalemate. Thanks for nothing.
Nov 8, 2009 at 8:21 AM
