1970 Ford Mustang Oil Pressure
500 MILES • V8 • 2WD • AUTOMATIC
MIK413
The 302 V8 has a recent rebuild from what I was told when I purchaced the car. The block is from a 1987 truck or SUV. I have a problem with my oil pressure, at start the pressure reads 45 which I feel to be low to begine with, and when warmed up to 170 degrees the pressure drops to 15 lbs and lower. Recently as I drove the car I noticed the oil pressure drop to "0" and then bounced up to just below 20 lbs. I ordered an new oil pump but I'm wonering if the pressure guage may be reading wrong also.
Sep 26, 2010 at 8:13 AM
  • 75,988 POSTS
Check the oil pressure with a mechanical gauge,if normal replace the oil pressure switch. If abnormal could mean oil pump and engine bearing.
Sep 26, 2010 at 10:37 AM
