1970 Ford Mustang Alternator
POPO1970
Electrical problem
1970 Ford Mustang V8 Two Wheel Drive Automatic
What is the easy way to check or test an alternator ?
Aug 26, 2009 at 10:06 AM
  • 31,937 POSTS
Hi there,
The best way to check the alternator on the car is to first make sure that the battery is in good condition with a load test, ensure that the terminals are clean & tight, if that is all ok, start the engine and with a Volt meter check the alternator out put voltage at the main alternator terminal, you will want around 13.5 volts this should not rise above say 14 V with the revs stepped up, if this is out of range have the alternator inspected by an auto electrician.
Mark (mhpautos)
Aug 26, 2009 at 10:49 AM
