1969 Ford Mustang Brake Lights
1969 FORD MUSTANG
64,000 MILES • V8 • 2WD • AUTOMATIC
EDDIEO
I am having a problem with the brake lights not coming on when the brake pedal is pressed. Also the turn signals do not blink but the warning flashers do blink.
The "brake" indicator light on the dash stays lit all of the time.
May 29, 2009 at 4:51 AM
Check all the fuses if all good- test the brake switch
For the turn signals could be the turn signal flasher if its separate from the hazard and the turn signal switch. Brake light On could be the E-brake needs adjustment or the brake master cylinder low on fluid
May 29, 2009 at 10:31 AM
