1968 Ford Mustang Starter Circuit
1968 FORD MUSTANG
100,000 MILES • V8 • 2WD • AUTOMATIC
MRMIST
I attempted to start the vehicle after a period of storage. I installed new plugs (gapped to .034), distributor cap, rotor,(did not change condensor or points), new plug wires 7mm sized for a 390ci.
The engine is a 289, I went to start, it began cranking. I was waiting for the fuel to get up to the carb, I shut it off with the intent of cranking again. The engine continued to crank. I got out, pulled the accel super coil feeding the distributor, it still cranked over. I pulled the ignition and starter feeds off the (ignition relay by the battery), it continued to crank. I had to pull the positive off the battery before it quit cranking.
Dec 17, 2009 at 2:18 AM
  • 31,937 POSTS
Hi there,
I would say that the starter solenoid on the starter motor has stuck in the engaged position, get the starter checked out, start here.
Mark (mhpautos)
Dec 18, 2009 at 12:14 AM
