1968 Brake Problems
FEDORA28
I have a 1968 Mustang with about 70,000 miles, 302 v8 with front disk brakes, every time i slow to a stop the brakes make a grinding sound as though the pads were worn down but i have now replaced the pads, rotors, and calipers. it seems as though the rotor is rubiing against the top of the caliper on the inside (there's a line where you can see it rubbing), any thoughts??
Nov 3, 2007 at 6:13 AM
MERLIN2021
  • 17,250 POSTS
You have checked the wheel bearings? If they are loose enough, the rotor will tilt...Also try new slide kit!
Nov 3, 2007 at 6:55 AM
