1967 Ford Mustang Why does this mustang keep doing this
LIUKANGSKUNGLAO
Engine Mechanical problem
1967 Ford Mustang V8 Two Wheel Drive Automatic
I was driving this mustang and as i was driving at around 35 mph the engine began to putter like it wanted to give up on me. i tried to give it more gas thinking that not enough gas was getting to it and the engine died. so i pulled over and the engine started no problem. but as i was driving again i could not exceed 35 mph Approx. so when i rev up the engine it still putters and sounds like it wants to die but idling it fine can you please help me!!!!!!!
Apr 16, 2010 at 9:51 AM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Apr 16, 2010 at 10:29 AM
NEVERENOUGH
Hey, lui. I ran across your post and noticed the list of things which may cause your problem pretty much relate to later model "computer" cars. Yes It does state "disregard if these don't apply". And most don't.
Has your Mustang been recently tuned up (say within the past 5 to 6 thousand miles)? If so, did it receive a "minor" tune...plugs, points, condenser, cap, rotor, timing checked and set, air filter and so on? Or has it had a more extensive "major tune", which would add the additional steps of carbureator work, compression check, fuel system testing, plug wires,and so forth?
I ask you this because it relates directly to a diagnosis of the problem you are having. Without knowing your Mustangs condition... I can give you some speculation of common causes and relatively simple remedies.
If indeed the pony is tuned up,start with the "most likely" causes. Fuel filter...fuel pump...carbureator.
An inexpensive fuel filter can cause the problem. Next a not too expensive fuel pump could be cause. Leaving the carb. (notice how I abbreviated it this time. 'cause my spelling is not good!) which VERY well can be the culprit.
Your Mustang, as stated...V-8, I'm guessing a 289 with a Ford 2 bbl carb. These carbs have their pros and cons. When they are clean and set up right they are excellent. They are however prone to picking up varied stuff within the fuel bowl which quite often can cause your symptoms (and a lot worse).
It wouldn't be the first time the top was pulled on one of these 2 barrels, float lifted out, revealing some sort of crap settled over one or both the main jets.
Your starting and idle could still remain intact, but any sort of rpm or power developement would react as you have described. Additionally, heavy or full throttle, (in some cases) may still be functional. I,m NOT saying to go out and nail the throttle around the block a few laps...I'm just saying!!
SO...if this gives you some direction. Get back to me if you are still at a loss to curing the pony. With some more detail, maybe I could be of more help....
neverenough
Apr 18, 2010 at 4:43 PM
