1967 Ford Mustang Oil Pressure is High
141 MILES • V8 • 2WD • AUTOMATIC
RRSANCHEZ28
I just started working on my car after sitting in the garage for a year. I noticed that the oil pressure is always high. Do I need to replace the pump? Help
May 4, 2009 at 12:32 PM
  • 75,988 POSTS
Sir-What you need to do is check the oil pressure with a mechanical gauge-if its normal replace the oil presssure sending unit abnormal could be the oil pump pressure relief valve not opening. Might consider and oil/filter change-could be sludge
May 4, 2009 at 12:46 PM
