1967 Ford Mustang Oil Pan Gasket and Oil Pump and Fuel Pump
1967 FORD MUSTANG
38,000 MILES • V8 • 2WD • AUTOMATIC
SANSIONG
How much would it cost to change the oil pan gasket for a 351 Windsor engine V8 5.8L 4BB because it was leaking? The previous owner change the engine of this car. I was also planning to have the mechanic change the oil pump since they are going to remove the oil pan anyway. And also how much would it cost to change the fuel pump gasket because it was also leaking? Thank you in advance for your help!!!
May 17, 2010 at 7:40 AM
HMAC300
  • 48,601 POSTS
you are better off to get a quote from a pro in your area. prices vary throughout the country.
May 20, 2010 at 11:42 AM
