Mark:
If the car isn't driven very often, starting it from time to time (just to keep it running) or very short trips will foul the plugs. That will cause a rough idle. Also, I don't know how old the fuel is, but that can cause it to.
As far as the carb, the accelerator pump won't cause a leak. However, a sticking float will and it will dump fuel which can also have an effect on the idle. I recommend taking the carb apart, checking it the needle and seat are in good condition, make sure the float actualy floats and doesn't have gas in the it, and give it a good cleaning if everything looks ok. If that doesn't help, then the rebuild may be the answer.
Let me know what you find.
SPONSORED LINKS
Sunday, March 8th, 2009 AT 5:17 PM
