1966 Ford Mustang Wiring diagram for add on cooling fan
240,000 MILES • 6 CYL • 2WD • AUTOMATIC
DIGDUGMUSTANG
I need to wiring an electric cooling fan, I have the fan installed, Hayden thermostat control system, and I want to have the fan come on when the engine is turned off, and the fan to turn off when the engine is turned on.
I would like to have a wiring diagram to do this if I can. The diagram will need to be in detail with the relay instructions, I think I will need one, which wire to which number on the relay.
This is to solve a problem of the car will not start until it has cooled down after it has run and heated up. A vapor lock problem I do not seem to be able to solve.
Mar 20, 2009 at 3:05 AM
MERLIN2021
  • 17,250 POSTS
I dont think the fan will help, check the lower radiator hose, the tend to collapse on the old mustangs, tried that yet? And is cranking speed normal or slow?
Mar 20, 2009 at 6:19 AM
