1966 Ford Mustang turn signal problems
86,000 MILES • 4 CYL • 2WD • AUTOMATIC
MEXICANOMAN27
my right turn signal stays down after using it causing the blinker to keep going unless i pull the lever back up. Is there something that i can do to make this stop?
May 31, 2010 at 9:46 AM
DOCFIXIT
  • 18,828 POSTS
Probably has a broken return tab remove wheel inspect will see the plastic tab broken . replace switch
Jun 1, 2010 at 8:05 AM
