Need help Car not wanting to start just started turn key the sylnoid will click changed had the starter checked tested 3 time tested good had battery checked good took set of jumper cables grounded battrery to frame to check ground, nothing but click. next jumped the clynoid to small post would click tried a couple time then started one time the starter keep turnning and had to pull the battery post to kill the engine but cranked a few time after that but went bak to clicking not your normal low battery click just one click from the cylnoid any suggestions.
Thanks
Mike
Thanks
Mike
Apr 12, 2009 at 12:19 AM
