1966 Ford Mustang Neutral safety switch
BLEVERMAN
Electrical problem
1966 Ford Mustang V8 Two Wheel Drive Automatic 0
Power at ignition. No power at solenoid. Power at leads to neutral safety switch. How do I check the neutral safety switch by itself? It is new and I've checked the adjustment twice and it is correct. HELP. Also, if I run a wire directly to solenoid from ignition then it starts.
Mar 31, 2010 at 11:34 AM
BLUELIGHTNIN6
  • 16,542 POSTS
follow link below to learn about testing neutral position switch
http://www.2carpros.com/how_does_it_work/how_a_neutral_safety_switch_works.htm
Mar 31, 2010 at 1:35 PM
