1966 Ford Mustang electric fan
RFMUSTANG
Electrical problem
1966 Ford Mustang V8 Two Wheel Drive Manual
Electric fan stop working I tested the motor it works I changed the fuses and relays still does not work,I purchase the fan and radiator at Hotrod Air which is out of business any help would be great.
Thank you
Rich
Jul 18, 2010 at 4:45 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check out the sensor that tells the fan to come on. assuming this is installed aftermarket, i'm not certain of your exact fan setup.. also make sure the radiator cap is not cracked..
Jul 18, 2010 at 6:15 AM
