1966 Ford Mustang Car dies after one minute
162,000 MILES • 6 CYL • 2WD • MANUAL
DURANT9999
Hey everyone.
My 66' mustang will start sometimes right away sometimes after a great deal of effort. It runs for a minute (seems like revving too much) then it will slow strat to run rougher and rougher over the course of a minute until it dies.
I had a loose tail pipe fitting at the manifold which I corrected. While I was underneath the car, I notice a small hole on the bootom of the manifold which looked like it fitting for a tube or something, but had nothing attached to it.
By the way I, I sealed off the vent rod with JB weld. I had read on here and heard from a tech that this was okay since the vent rod is only shock absorber for the accelerator pump.
Thanks,
Jim
Aug 11, 2008 at 3:06 AM
2CARPRO JACK
  • 11,533 POSTS
You should never seal a vent on a carb. Sounds liek you may have a carb that has a float level to high.... does it dump fuel into the carb when running? Have you tried spraying carb cleaner around the base of the carb to see if it has a vacuum leak?
Aug 11, 2008 at 7:23 AM
